For the roll up door, you could utilize a 2GIG Thin Door/Window Contact combined with a Miniature Overhead Door Switch (4532L) The DW10 monitors the circuit using the aux terminal in the sensor and when the magnet is moved away from the switch, the circuit opens, triggering the DW10 to report to the panel.
We are just going to move our existing keypad in the warehouse to our new area.
When moving the keypad, ensure that it is powered down completely first. If moving the main panel you will also want to ensure that the antenna remains plugged in properly. Be sure to check signalling before installing the panel in its final location.
