On another thread the Honeywell 5898 was recommended as a better bet with cats, so I ordered a couple of them. I am working on adding them to my system, however the configuration for these doesn’t seem to be documented anywhere.
The included documentation was fine for configuring the sensor itself, I installed the “animal immune lens” and look down mask. I assume I would use the lens masking stickers if I wanted to exclude specific areas from PIR (e.g. a cats favorite climbing spot, a stairway, etc).
I think I am ok on all but the “equipment code”. I currently set it to the 5894PI as the 5898 is not an option. Does this field matter that greatly, or is it more informational than functional?
Sensor Type: (04) interior follower
Equipment Type: (1) motion
Equipment Code: ???
Serial Number: xxxxxx
Equipment Age: (0) new
Loop Number: 1 (set to low sensitivity)
Reports: (1) enabled
Supervised: (1) enabled
If I was to program loop 3 for temperature monitoring, do I use the same equipment code just different sensor types and reporting disabled?
