Adding DSC Impassa Keypad to Qolsys IQ2+
I will be replacing my DSC Impassa with a Qolsys IQ2+ panel. I have 2 DSC Impassa external keypads along with the Impassa. Can I use these to also control my alarm system?
Unfortunately no. I believe the model you are referring to is the WT5500, correct? If you have a different model, let me know!
The power G version, the WS9LCDWF9 is compatible, but this is not the same model as used with Impassa.
The one I am referring to is the WTK5504 Wireless Touchscreen. I had wondered by figured I couldn’t use the old Impassa panel.
Also, I have the Qolsys compatible with DSC.
Ah, thanks for providing the model. Unfortunately I don’t think any of the DSC 433mhz keypads can be used. Only the Power G model is listed as compatible.
You can actually view a list of all officially compatible sensors and security peripherals here. Keep in mind these are confirmed compatible, there may be compatibility with an unlisted 433 sensor, but I would not expect that with a Keypad.
Great. Thanks for the reply. I’m curious to see if I can make it work with the wireless keypads.
U can also get additional touchscreen keypads for the Iq panel if u would
Yep, the IQ Remote is another option for any IQ Panel 2+, and uses wifi to connect.
It probably be better to say it uses the panels WiFi access point
