I am interested in adding a 2nd keypad to my Concord4. Based on the installation manual I found online (and looking at how my current keypad is wired), I believe I simply attach the 2nd keypad wires to the same terminals as my existing keypad, correct?
Also - will any programming have to be completed in order for the 2nd keypad to work correctly?
It’s been a while since I’ve programmed a Concord 4 but yes, you attach it to the same terminals as the first keypad. I don’t recall any additional programming required. I think it detects each Superbus 2000 device and just uses what you have wired up. Check out the sections with Superbus 2000 in the title in the Concord 4 installation manual.
