Add a Phone for Bluetooth Disarming on IQ Panel 4
Bluetooth disarming automatically disarms the system from an armed away state when the connected mobile device comes within range of the panel.
To add Bluetooth devices using the panel:
  1. Open the menu on the home screen, then tap Settings.
  2. Tap Advanced Settings.
  3. Enter the installer code.
  4. Tap Installation.
  5. Tap Devices.
  6. Tap Bluetooth Devices.
  7. Tap Add Phone.
  8. Select the correct mobile device from the Available devices list.
  • If the mobile device does not appear, verify Bluetooth is turned on in the mobile device by opening the Bluetooth page and then tap the refresh button. The panel searches for all available and in-range Bluetooth devices.
  1. Tap Pair. A message on the mobile device may also need to be acknowledged.
  2. Configure the Bluetooth device as desired.
  • In Name, enter the desired name for the device.
  • Using the Disarming dropdown menu, select to Allow Disarming or Disable Disarming.
  • If partitions are enabled, the user can select which partition the Bluetooth device can disarm in Partition Access. A Bluetooth device can only be assigned to one partition at a time.
  1. Tap Save.
