Is there a zwave dry contact approve relay for adc eco system ?
Officially compatible devices for the IQ Panel 2+ can be found here. (Tested and confirmed by Qolsys)
Alarm.com’s official ecosystem page is here.
There are no basic contact closure relays, but there would be a couple options.
- Use a plug-in module to switch a power supply which triggers any relay of your choice. I would recommend this route.
- Try one of the available relays for Z-wave. I have used the Fortrezz Mimolite with 2GIG Panels successfully, though I recall having trouble with it on the Qolsys Panel. In either case, the sensor input portion will not work, only the relay.
