ADC-W110 not connecting
Will do!
Ok, whats the signal strength, now?
I am not seeing a response from the W110, but the connected camera is responding to pings, so it is a bit odd. Did you move the camera to a switch?
Is the camera still connected to the W110?
No switch yet. Thr camera is still connected to the W110. I moved an AC1200 extender to rhe same room…, but I’m not sure how to have the W110 link to it. I didnt have enough time last night to play around to get thst set up.
Hey Jason, what do you see now?
The W110 which is associated with the camera is still reporting as though it is disconnected. It is not providing DDNS updates and not responding to pings. I cannot see an updated signal strength.
Can you try power cycling the W110?
Do you have it connected to the AC1200?
Ill try when I get back home. How do I connect it to the extender? I had it in 5 GHz before, but after resetting it, I think its in 2.4GHz, now. Its connected to my router, and is across the room from the W110.
When setting up your extender, use 2.4ghz. When you get to Configure your Extended Network Settings, opt to use a unique SSID for the extender network, so that the camera can only connect to the extender.
