Doorbell just completely died the other day. I took it off and metered the power coming to it and it’s still showing the proper ac voltage. Pins on the doorbell seem fine.
Are there any light on it all?
If the battery showing any signs of puffing up or having other damage?
No lights, completely dead. Battery seems fine but who knows.
Hello!
Thank you for confirming!
To help us determine whether the issue is with the doorbell itself, could you temporarily test your ADC-VDB770 using its Micro-USB port?
Please remove the doorbell from its mounting plate and connect it to a known-working 5V DC Micro-USB power supply. This is just to test if any LED lights up when you try to turn On your doorbell. If an LED lights up, please let us know the color of the LED and its flashing pattern.
This will help us narrow down the possible cause and determine the appropriate next steps.
Thanks for your patience!
It lights up to a solid red and then blinking red then eventually solid green
That’s actually a positive sign! The LED sequence indicates that the ADC-VDB770 is powering up and eventually establishing a connection to Alarm.com.
Please disconnect the 5V DC Micro-USB power supply from the doorbell and reconnect it to its hardwired transformer. Once connected, power it On again and check whether it can reconnect to your panel.
If it does not reconnect, please let us know the current status of its LED indicator.
What do you mean power it on again? Theres no power button. You already know it doesnt power on from the hardwired mount - thats the whole issue!
Thanks for clarifying.
What we meant was to check whether the doorbell will power on again once you reconnect it to its hardwired transformer after testing it with the Micro-USB power supply. This is another way for us to determine whether the issue may be caused by a connection problem between the doorbell and the transformer and whether reconnecting it resolves the issue.
We understand that the doorbell appeared to be completely unresponsive when initially connected to its hardwired transformer. If we are not mistaken, your transformer was supplying the proper AC voltage to the doorbell when you tested it using a metering device. Is that correct?
If the doorbell responds to the Micro-USB power supply but continues to remain unresponsive when you reconnect it to its transformer, please let us know. We will escalate this to Alarm.com for further investigation.
Thanks for your patience.
The doorbell still shows no signs of power when attached to its mount. The ac reading going to the doorbell is normal.
