I just received the ADC-VDB770 yesterday and installed it. I’m able to look at the live feed from the app and alarm.com but the panel is throwing an error when trying to view.
It says “Video device not responding, check power and network connection.”
Any idea what can I do to fix it? It also seems quite sluggish, even thought it’s on my 5Ghz SSID.
Switch the ADC-VDB770 to a unique 2.4ghz SSID. 5 is faster, but it does not have the same reach, and if the quality of the signal at the device location is not high enough speed won’t matter.
Reboot the IQ Panel 2+. Settings > Advanced Settings > Reboot Panel.
The only way I could get it to work was to switch both panel and doorbell cam to my 2.4GHz network and then reboot the panel. However, it still takes about 10-12 seconds for the feed to come up. I know the VDB-770 is relatively new, but this looks like a software issue. Any chance we’ll get some new firmware that resolves the perf issues?
We’ve heard reports from a couple users that the initial connection takes a little longer than expected. In short, yes I would expect many firmware updates, but I could not say specifically if this concern will be immediately addressed. I would definitely anticipate improvements to be implemented based on reports from users though.
Do you notice a difference when your phone is connected to your local wifi vs when you are on mobile data?
Was there ever a resolution to this? I think I’m experiencing the same problem with mine. The ADC-VDB770 is taking too long to connect to my panel and it’s timing out.
