I finally give in and purchase ADC-T40K-HD installation was super easy and everything seems to be on and working. I do have few question that are not answered in the manual.
I have Motion sensing enable and it takes forever to turn off the screen. I tough that is not working but if finally did. Does anyone knows what is set time for the screen to turn off?
If i disable Motion sensing screen turn off pretty quick. - Can anyone get more info on this from ADC?
Also If you have ADC remote sensors and you pair them to the thermostat my old T3000 use to have an icon that look like a thermomate in the corner. That is how i knew that temp sensor are paired to the thermostat. If you unpair them that same icon will go away. I don’t see any indication on the T40 when you pair temp sensor to it. Can this be confirm with ADC if that should be display or not.
And last but not list. T3000 had a zwave parameter manual that could be manually change and adjusted when other zwave controllers were used does anyone knows if anything like that exists for t40
None of these questions have documented answers. At this time we are looking into them through ADC to see what information is available. We will follow up here when we have more information.
This variable is currently unknown (or at least not documented). If Motion-detected wake sensor is too sensitive or not sensitive enough you can calibrate it locally at the TSTAT:
Tap Installer Settings.
Tap Advanced Configurations.
Tap Calibrate Motion.
The T40 will not indicate that an RTS is connected to it via display locally, just via the thermostat’s card in ADC.
I do not see anything that exists for the T40k-HD at this time.
Is there a way to find out t40k z wave variable parameters
Alarm.com representatives indicated that the requested information was not documented. It may be possible to find that information online in the future but it is not available.
