So what’s the deal from ADC regarding getting full control of the T2000? (Advanced and Installer tabs)
Cuz I am getting tired of having a “Smart” thermostat that I have minimal control of. I am debating putting my carrier Tstat back up, and trashing the crippled T2000.
Just a heads up, I think these are being configured improperly for heat pumps. For example, Under installer, “Aux heat stages” are your stages of heat, whereas “heat pump stages” are actually your stages of cooling, and under advanced, “pump staging delay” is the delay between cooling stages (very confusing). Click the “?” and it will tell you.
So, in my case, I have 1 stage of cooling, 2 stages of heat with a differential of 5°, and staging delay of 15min (Y first stage heat/cool, W AUX second stage heat). Hopefully the below is properly configured for the above.
What was the solution to get advanced access. Mine does not appear to show up yet. Now that temps finally dropped want to make sure settings are right and working the way I want. Appears ok but want to be sure before too many more days of cold temps.
The solution is to contact your dealer/provider and have them enable the features on your ADC interface. Not all providers want you to have full access. In such a case, where your provider doesn’t want you to have installer and advanced tstat access, you are SOL.
