ADC Sump Pump Monitoring
The PG9985 should work fine. If you would rather use a float switch or even try to wire into your existing alarm float switch you can connect a normally closed float switch to an S-Line Extended sensor.
Alarm.com launched a smart water valve at CES. That would be the best option although they also support the Fortrezz water valve.
