I am thinking about getting a few outdoor cameras and am debating between a few options. Are there any installation instructions for the ADC cameras such as the 721 so I know what I would be getting into and what the requirements are. Thanks.
These would be the necessary steps and required items for installation of the ADC 721w camera.
Required Items for Installation:
- ADC-V721W camera and power adapter (included)
- Broadband (Cable, DSL, or Fiber Optic) Internet
connection with Wi-Fi router - A Wi-Fi enabled Computer, tablet or smartphone
- If the router does not have a WPS button, and the
camera will be connected to a wireless network, you
will need the case-sensitive SSID (wireless network
name) and the network WEP or WPA key (if encryption
is enabled at the router)
Install the Camera(s):
- Connect the camera’s AC adapter and plug it into a non-switched outlet.
- From a computer or smartphone, connect to the Wi-Fi network named “ALARM (##:##:##).” The numbers in
parentheses will be last 6 digits of camera’s MAC - From a web browser type in “http://V721install” and press enter.
- This should direct you to the camera’s internal configuration website. Follow the on-screen instructions
to connect the camera onto a wireless network. - From a computer on the same network as the camera, login to your Alarm.com account
- Navigate to the Video Tab on your Alarm.com website. Video Tab -> Video Device Settings -> Add Video
Device
WPS Button Key (press and hold for):
Reset Camera - 15 seconds
WPS Mode - 3-5 seconds
Wireless AP Mode - 5-7 seconds
LED Status -> Description
Install
All off ->Power off
Solid Red -> Power on, system booting
Green blink every second ->Local network connection with local IP address
Solid Green-> Full internet connection with Alarm.com IP
Blinking Blue -> WPS learn-in mode
Blinking White -> Wi-Fi access point mode
Trouble Conditions
Solid Red -> No local or Internet connection
Factory Reset
Red blink every 0.15 second + Green blink every 0.15 second -> Restoring factory
