Got My IQ 4 and about to embark on switching everything over from GC2
I am guessing I should start this on a weekday? If I start on the weekend, You can not switch over the system on your end, even if I go through the web portal to do so?
Can i program sensors over weekend, then switch over on Monday? This way Incan keep the 2 gig panel protecting my home yet I can get a jump on things over the weekend
Also, howmdo you clear all data out of the 2 gig panel?
Just dont want to be stuck in the middle of things and have my home not be able to be monitored
I know I have to reprogram all my zwave devices. But will ADC save my rules and schedules and then I can just repopulate the zwave devices? Or must I reprogram that all from scratch?
I am trying to be strategic about this. Any tips would be so appreciated. Timing and order of doing things is something I would like to get your insight on
You can perform the swap at any time, 24/7.
When you have the new panel ready to connect, use the Swap Cellular Module/Panel option in your system manager. The change takes place immediately when you follow the steps.
No, automation rules will need to be recreated. You’ll have all new Z-wave device IDs and instances.
