Does anyone know of a 345 mhz repeater that will work with an IQ Panel 2? Thanks!
You can use the Alula (Resolution Products) RE524X. Itll repeat 345MHz and is tested compatible by Qolsys to work with the IQ Panel 2 and IQ Panel 4.
If you are using the IQ Panel 2+ with PowerG radio, depending on how many sensors need to be repeated, you can switch to a PowerG sensor as they offer increased range over 345MHz
Great, thank you!
Apologies for bumping this thread. I found this through google search as I’m also in search of a compatible 345MHz repeater for my IQ Panel 2. I have Honeywell flood sensors that keep getting disconnected. I believe the signals are weak because they’re too far from the main panel.
@tyler will this work immediately once paired with the IQ panel or do I have to go through re-learn mode for my sensors?
The RE524X has enrollment steps in the manual here.
The sensors do not need to be deleted and paired again in the panel but I believe you still need to trip all the zones with the RE524X cover off to register them in the RE524X.
