345 Card Antenna Wire Question
Just received my IQ5 Panel - along with the 345 card I ordered to support a 345 Firefighter.
I was able to install it without issue.
There is a white wire - which I’m assuming is the antenna. Is there a good / right way to run that wire? I did some searching but couldn’t find that info.
Thanks!
The white antenna attached to the card is for 345MHz sensor communication reception.
It should be run out the back of the panel and into the wall (if wall mounting). Try to avoid having the antenna touching any metal or other wires in the wall as this can cause signal attenuation issues.
perfect. thanks for the quick reply!
