2gig temperature sensor
HI,
I would like to add temperature sensor on all rooms to monitor and create thermostat rules.
I know that alarm.con have one but can I used other temp sensor like Honeywell ?
Will I be able to learn them to the GC2 and see the temp with alarm.com
May I another question:
I have many Lutron Zwave light switches, can I learn them to GC2/GC3 panel?
Thanks :slight_smile:
Only the Alarm.com Remote Temp Sensor works with Alarm.com and the ADC T2000/T3000 thermostats. Other models of temp sensor will not function at this time.
If they are Z-wave, most any light switch will be compatible due to their simplicity. If they are learned into a different controller they would need to be removed from that controller first.
Thank you Jason.
I have the older 2GIG CT100 thermostat, will it work with alarm.com temp sensor?
No, the Alarm.com remote temp sensor only works with the Alarm.com T2000/3000 thermostats. It does not work with any other thermostat.
I guess its time for upgrade…
Thanks
