I have several of the 2GIG-SMKT3 and want to add them to the IQ Panel 4. I assume that in order to take advantage of the smoke/fire/freeze function I need to add/activate the inclusion 3 times and set each one to a different loop. Outside of that is there anything else that I need to do in order to allow them to work. I tried this and each time it comes up as Smoke/Heat.
Any help would be greatly appreciated.
Yes, programming would be the same as it is on 2GIG panels, where three different zones would be needed. The loop determines what function is monitored.
Smoke Detector - Smoke/Heat/Freeze SMKT3/8-345
Smoke Programming
Sensor Type: Smoke Detector
Sensor Group: 26 Smoke-Heat
Loop: 1
Sensor Name: As Desired
Chime Type: As Desired
Voice Prompts: As Desired
Source: 345RF 2GHeat Programming
Loop: 2
Source: 345RF 2GFreeze Programming
Sensor Type: Freeze
Sensor Group: 52 Freeze
Loop: 3
Source: 345RF 2G
Thank you for the info Jason.
