Before replacing the unit, you’ll want to ensure a few things first:
How old is the unit? There should be a date code on the unit.
The manual recommends 3 AAA 1.5V 1100mAh PC2400 Duracell Procell or Energizer E92 batteries.
If indeed a low battery issue, you will want to remove the batteries for at least a minute before replacing the batteries and remounting. This will allow for a proper power down sequence. You will also want to ensure that the detector is mounted flush with the mounting plate once reinstalled to prevent a tamper.
If you are not getting a low battery warning at the panel, there are three possible causes for chirps (not just a low battery), and you would determine which is the cause by the delay in the LED flash:
Alarm Trouble: When the alarm has a general fault, the yellow LED blinks once every four seconds
and there is a chirp every 48 seconds. After 4 hours the 2GIG Control Panel displays a loss of
supervision message.
Alarm Dirty Feature: When the alarm has been contaminated, the yellow LED blinks once every 8
seconds and there is a chirp every 48 seconds. After 4 hours the 2GIG Control Panel displays a loss
of supervision message.
Low Battery Detection: The Wireless Smoke/Heat Alarm is powered by 3 AAA batteries. The alarm
regularly checks for a low battery. If a low battery is detected, the transmitter sends a low battery
message to the 2GIG Control Panel, that displays the alarm’s ID at low battery. In addition, the
yellow LED of the alarm blinks every 12 seconds
