So my panel stopped connecting a little while ago and I only just got the chance to run a cell test. That fails, though I am seeing 18/31 signal strength and it says trying to register… I did lose power to a couple of circuits so I powered everything back on and no luck?
We’ve spoken with ADC and they have had the carrier send a reset command to the module. When you are able, try fully powering down the panel, unplug the AC transformer, then unplug the battery. Ensure the panel is off. Wait 3 full minutes. Then plug in the battery followed by the transformer.
After a few minutes, try running a cell phone test, any luck?
Next, try powering down the panel, ac transformer first, then battery. Verify panel is fully powered off, then remove the cell module carefully. Reinstall the module on the board and reattach the two screws. Make sure the antenna is firmly connected to the port.
Allow the panel to remain powered off for at least three minutes, then power up, battery first, then transformer.
It sounds like then that this module is malfunctioning, possibly damaged due to power fluctuations.
One more thing to try would be the steps in this video.
If the above does not work I believe that you will need to replace the module. This would be a direct replacement. Once you have the new module, let us know the module number by secure message and that you are ready to make the swap and we will associate the new module to your account.
So I installed a new Verizon LTE module and its not showing up in the control panel to do a cell phone test? I took it out and reinstalled it… but still no cell phone test shows up.
