The 2GIG-DW10-345 Manual specs show a .85 inch maximum distance. You could try to adjust or relocate sensor to better fit your needs.
If you have the wire leads for the DW10 sensor, you could use an external sensor wired into it. You could use something like this Seco-Larm SM-216Q or Seco-Larm SM-4601-L3Q
