I recently purchased a home with a security system. The system is a Go!control panel with door sensors, motion sensor and a single camera. It was being monitored by CPI They want to charge me $50 a month for monitoring. They have locked the control panel via the installer toolbox which will not allow me to add new devices or change any settings.
Before I go with any service I want to be sure I can use this equipment. According to all your sites information I will be able to if I can gain access to the installer toolbox. Is there a way to reset this code back to the factory 1561 or do you know the code that CPI uses so I am able to use this control panel.
I have already factory reset the panel and was able to get some access via the reset master code but the installer code was not reset. Because of the reset I have currently lost all programing of my sensors and camera. CPI will not give me the code. They will also not send someone out to reset the system because I do not have monitoring service with them and they will not let me sign up for service to get someone to come out to reset the code. The only way they will sign me up is with a 5 year contract and all new equipment.
Can you provide any assistance?
Thanks in advance.
