2GIG Go Control Panel Tamper alarm...
A panel or console tamper alert is relating to the tamper switch on the Go!Control panel itself. This tamper switch is located to the left of the set screw when opening the panel.
A tab on the back-plate depressed the tamper switch when closed. Make sure this tab is not cracked. Also check to make sure that the rubber cover to the tamper switch is intact.
There is almost always a physical reason for this alert to occur. Has there been work done on the panel in the last week or so?
