The 2GIG GoControl requires a special battery pack available for purchase from the manufacturer. 2GIG-BATT2X
To replace the battery in a 2GIG GoControl:
If desired, put the system in test mode with the monitoring station before proceeding.
Disarm the panel.
Power off the panel.
- Unplug the AC adapter from wall outlet
- Unscrew the top to remove the back cover.
- Disconnect the battery pack’s connector, and remove the old battery.
Plug the new battery pack’s connector into the connector on the Control Panel’s circuit board.
Reinstall the back cover.
Restore AC power.
Important: The Control Panel does not recognize that the battery is connected until AC power is connected to the power supply.
