Is there any way to REMOTLEY silence a tamper warning on my 2GIG GC# Panel? I have a Z-Wave lock on my property that I rent and guest are continually setting off the tamper when they mess with the lock.
Alternatively, can I disable the Tamper for the lock in my panel it will not alert?
It is not possible to remotely silence a panel tamper nor should a failed unlock attempt cause the panel to announce a tamper or warning. Could you describe the situation that is occurring?
Has it happened more than once? Where is the audible alert being generated? At the lock or at the panel?
Can you post an image of any errors that may be showing up on the panel?
