Ok, I just unlocked it a few times
Give a minute or two in between tests, try unlocking the door with each code that has access. So unlock with one code, lock, wait two minutes, unlock with another code, lock, wait two minutes, unlock with a third code.
Ok, I did that with the intervals of about 2 minutes.
Yeah, after digging into the signals I’m only seeing the open/close of the door sensor reliably report during that time.
It looks like the FE599 probably has a similar (or same) issue as it did with the GC2 prior to 1.13. I’m checking for additional info from ADC to see if they can confirm.
