Hi,
Is there an external antenna available for the GC3?
I note that there is one for the GC2 but with the re-design of the wireless sleds its not clear if there is a solution for low radio signal on the GC3.
Thanks,
Gordon
Hi,
Thanks,
Gordon
The antenna is by standard integrated into the module sled.
You can however open the sled and connect the ANT2X Attic Antenna. A small groove on the module sled allows the wire to be run out the back of the panel.
