For no know reason, my panel has started giving random Alerts for Console: Tamper… please advise if this is a known issue and how to resolve it.
The other day I set my alarm and upon returning and inputting the correct code, it immediately called monitoring I assume due to that panel tamper alarm…
Panel/console tamper means the tamper switch on the control panel isn’t being held closed reliably. It sounds like its borderline which is causing it to trigger over and over. Can you ensure the panel is closed securely? Also make sure the tamper switch isn’t damaged.
Right, I just meant remove(open) the panel from the back mounting plate and put it back…iI did that and it seems to have stopped the Alerts. I did notice that the battery seems to be bulging a little…is that normal or should I replace that (about 3 years old)?
