Summary and Step by Step
Adding water cop and FT-6 sensor to 2 Gig Panel and question on Automation!!
There have been a lot of questions about this and I will try to put together a clear set of instuctions based on primarily Jason’s helpful answers
Step 1. Adding a 2gig FT6 sensor ( temperature, flood, freeze)
A. This sensor will not be automatically detected using the find z-wave devices option. You must add and configure these manually. When you get to the step asking for the serial number, you can remove the tape on the battery for the panel to add automatically or you can ENTER the serial number that is ON THE BOX.
Also note that you should not place this directly on something like a metal water heater drip pan as it will trigger the sensor!!
You have 2 options
Option 1. This will make the entire alarm ring (like a fire alarm) and the central monitoring station will be notified. However, the emergency units will not be dispatched automatically.
RF Sensor Type: 08 – 24 Hour Auxiliary Alarm
Equipment Type: Flood
Equipment Code: (1065) 2GIG Flood Sensor
Serial Number: Learn – Tamper Sensor
Equipment Age: New
Sensor Loop: 1
Voice Descriptor: As desired
Sensor Reports: Enabled
Sensor Supervised: Enabled
Sensor Chime: As desired
Optionally you can then add the other temp zones:
Option B: This will result in the alarm NOT going off and the central monitoring station will NOT be notified.
This is not recommended as you are dealing with a potential flood. You MUST set up notification.
Use sensor RF type 23 instead of 8. this is the NO response option.
When you choose this, you will need to choose the contact option and not the motion sensor option
Everything else is the same as option 1. Remember to set notifications. and flood detection is Loop 3 to confirm
Step 2. Add Fortrezz Water cop
This is simple. Enable Z wave search on the control panel. Press the MODE button Once on the water cop to include
Step 3. set up notifications.
Add new notification. Select the flood detector option and set up notifications.
Step 4. When the flood sensor triggers a warning, close the water cop shutoff valve.
HERE is where I am stuck. In automations, it doesnt allow me to trigger closure with the sensor.
