2Gig Edge Sounder over Voice
I have a 2GIG Edge security panel through your monitoring service. When an alarm trips, the panel announces which zone/sensor triggered it, but the siren starts at the same time as the voice announcement, so I can’t actually hear where the alarm is coming from.
I know Vivint panels prioritize the voice announcement before the siren kicks in. Is there a similar setting or dealer-level configuration on the 2GIG Edge that delays the siren for a second or two so the zone announcement plays first? If it’s not available in standard installer programming, is there a hidden config option, an Alarm.com backend setting, or a firmware update that would enable this?
If this isn’t possible on my current panel, I’d also appreciate knowing if this is a limitation of the Edge hardware/firmware overall, or something specific to my install.
Per 2GIG, this is the design of the panel and there is no way to change it. Once there is an alarm, the siren will trigger and will not stop to announce the chime.
Let us know if there are any additional questions
