I just got a new 2GIG Edge and the radio signal shows 0/6. When I checked the covered in the area, the result shows full coverage for Verizon and AT&T (I have the later). I bought an external antenna in hopes of improvement and nothing has changed. Can I still register for the monitoring service or does it need to be greater than 0 (common sense tells me that is the case).
On a side note, I have AT&T cell service and it works in the house, even thought the signal is not the strong. How do it I know if the problem is the signal or and new] device?
The minimum recommended signaling is 2/6 bars. Since the panel is dual path, you can connect to wi-fi as well. What you need to do in order to connect the panel to service is run a successful cell test from the panel (after plan purchase and account creation). This would require at least 1 or 2 out of 6 bars.
Have you fully power cycled the panel? Typically, a fully power down for a couple minutes, then powering it back up, will allow the panel to reacquire signal from the nearest applicable tower.
To do so, with the system disarmed, power a panel down completely, power supply first then the internal battery, and leave it off for at least 2 minutes, then plug in the battery followed by power supply. Are you able to get any signal afterwards?
Machine to machine coverage can be different from cell phone coverage. Where is the panel located? Have you tried moving it around, like to an outer wall on a main floor. to get a better signal?
