I have a 2GIG Edge Panel, and the Image Sensor is not capturing and uploading to Alarm.com, I believe my Panel is on the latest Firmware, yet nothing. This used to work and upload to Alarm.com with previous provider. I have done a hard reboot of unplugging and removing the Battery for the 5 Minutes, but still nothing. No images are capturing and also the settings seem correct and the Camera is Enabled. Still Nothing.
On 2GIG EDGE panels with firmware 1.1+, the on-board camera can be configured to capture disarm images if service package includes Images and Disarming events and is enabled in panel settings.
I can confirm that your service plan allows for images, the panel is on firmware 1.3, and the Q304 On-Board Camera setting in panel programming is enabled at this time.
Have you set up photo capture settings? To do so:
- On the home screen, tap Settings.
- Enter the installer or master code.
- Tap On-Board Camera.
- For Photo Capture Settings, tap Details >.
- Tap the toggle switch for the events to enable or disable photo captures for it.
- On panel firmware version 1.2+, verify the Upload captured images to Cloud checkbox is selected at the bottom of the panel screen. This allows photos to be uploaded to Alarm.com.
- Once complete, tap The Save button to save and exit panel programming.
That was it. The Enable to Cloud was not checked.
Glad to hear it. Let us know if you have any additional questions.
