When I say bandwidth, I mean LAN bandwidth. Accessing the camera stream from Alarm.com means they have connection to ADC, but video is separately streamed directly to both the SVR and the Panel (when working, I know there is still an issue there) across the LAN.
These are duplicate streams, and modern networking equipment sometimes has optimization settings in their software which can impact these streams.
I’m not seeing the router model number in this thread, can you please confirm the model number of that router?
I am having same problems. I think the panel can find the cam matching the user and pw. But then shows as DEVICE OFFLINE. I tried using without a special character, but camera requires one for the pw. PW has 10 char and upper and lower case and one special character and numbers.
Under settings - saved video - resolution, chose HD instead of full HD. The panel does not support the full HD resolution. This will also change your recording on SVR if you have one though.
