I have 5 2GIG-DW10-345 they are learned into the panel using recommended settings. ADC see the sensors but when opened they do not chime, or go off when the panel is armed. The panel is a 2gig gc3. ADC always shows closed. Any help would be appreciated. Activity monitoring is on
A couple things to check here:
If you have an e-series panel, make sure you have selected the correct e-series or non-e-series equipment type in sensor programming.
If you have a standard GC3, double check the Loop number in programming. It should be 2.
That was it. I was not selecting the eseries thank you.
