I am getting a non-stop single beep from two 2GIG Wireless Carbon Monoxide Detectors (2GIG-CO3-345); I removed the old batteries, waited 30 seconds, and replaced with new lithium batteries, but both are still beeping. I also noticed that the test buttons will not hush them and both are somewhat hard to press. The recommended replacement date was February 2018; in the meantime, is there a way to have those working (without the annoying beep) and monitored until I order new ones (if both have to be replaced)?
I have one installed near the kitchen but there are no gas appliances nearby (only a gas fireplace located within 25 feet); since I already have a CO2 detector near the fireplace, do you recommend relocating the one on the kitchen to an attached garage (especially since the master bedroom is right above it)?
Is there a wireless siren compatible with the 2GIG-CP21-345E and the 2GIG TS1 Wireless Secondary Touch Screen Keypad (2GIG-TS1-E)?
A few years ago, I ordered three yard signs but since you changed the phone number, is there a way to get a replacement?
Thank you in advance!
