04/13/2026 Alarm.com Release Notes and Bug Fixes
User Activity Reports for Employee Management
Business Alarm users can now gain added visibility into employee access with the new Alarm.com for Business User Activity Report. Compare expected in-office days against real employee activity to get an enhanced line of sight into workforce trends and make more informed business decisions. Alarm.com website > Select Enterprise/Location > Activity > Reports > Add
Obscure User Codes Locally on GC Touch Panel
GC Touch panels now offer the ability to obscure user codes in the User Management screen that is shown locally on the panel touchscreen.
ADC-VDB755P Door Station Audio Mode Selection
Users can now choose their preferred audio communication mode for the ADC-VDB755P Door Station. A new Audio Mode dropdown is available in the camera’s audio settings, allowing you to select your preferred option. “Continuous Talk” allows both parties to speak simultaneously, similar to a standard phone call. “Push to Talk” allows only one person at a time to speak, similar to a walkie talkie. Alarm.com website > Video > Settings > Select Device > Audio
ADC-V515 Firmware Upgrade
Alarm.com is releasing a firmware upgrade (v0.0.5.798) for the ADC-V515 camera. This upgrade includes Wi-Fi reset functionality, SD card recording triggers, and stability enhancements. Existing devices will be updated over the coming weeks through an automated overnight firmware upgrade process.
Updated Options for ADC-V731B Minimum Delay Between Clips
ADC adjusted the selectable options for the Minimum Delay Between Clips setting on the configuration page for ADC-V731B recording rules to simplify these options and promote better battery life. Alarm.com website > Video > Recording Rules > Add New Rule
Select All AI Video Event Search Clips for Clip Donation
Users can now use the “Select All on Page” button to select all displayed clips when choosing saved video clips to share with Alarm.com for feedback on the AI Video Event Search feature. Alarm.com website > Video > Saved Video Clips
AI Video Event Search Clip Donation Tooltip Improvements
ADC updated the AI Video Event Search clip donation tooltip to make it clearer how the clip donation process works. Alarm.com website > Video > Saved Video Clips
Bug Fixes
  • Resolved an issue that caused video stream loads in the post-installation steps for the ADC-V731B camera to take abnormally long. Mobile app > Video > Settings Cog > Add Device
  • Resolved an issue that caused duplicate Smart Arming schedules to appear on the user website when navigating between linked systems. With this update, the correct Smart Arming schedules now display for each system. Alarm.com website > Automation > Smart Arming
  • Resolved an issue affecting ADC-V730 cameras on firmware version 05019 that occasionally prevented Business Activity Analytics (BAA) from loading the camera image behind a BAA heatmap. With this update, BAA will now show the accompanying video stream along with the heatmap overlay. Alarm.com website > Business Activity Analytics > Heat Mapping
  • Resolved an issue affecting GC Touch panels that caused the panel to lose its live stream functionality after a factory reset or an OTA firmware update.
Great to see them continue to make improvements.
might be a silly question - but how are those updates / improvements delivered?
i figured it would be via updates to the panel - but my panel (iq5) hasn’t downloaded an update since i installed it a few weeks ago.
thanks!
Not a silly question. These updates and fixes refer to Alarm.com specifically, not the Qolsys IQ Panel. Unless referencing a specific camera firmware these would be live in Alarm.com.
Qolsys panel firmware is separate. Firmware patch notes and update instructions for Qolsys firmware can be found in the Product Updates section of the forum:
Once a new firmware update is released for the IQ Panel 5, you can find that update there. Currently only the default FWof 5.0.1 exists.
thanks for that info.
so for say camera firmware - the cameras would get the firmware directly from ADC?
the system i replaced would download firmware to the panel, which also had firmware for the cameras, and the panel would distribute the firmware.
thanks!
Qolsys panel firmware and Alarm.com camera firmware are separate.
Alarm.com camera firmware is typically rolled out by Alarm.com automatically. You can always check to ensure your camera is on the latest firmware through the Alarm.com video section.
Qolsys panel firmware is released by Qolsys and usually needs to be updated by the end user manually via a special code called a patch tag. Some FW updates are automatic (if this setting is enabled) but if the releases from the IQ Panel 4 are any indication, this is rarely used. The majority of FW updates required the patch tag and I suspect the same for the IQ Panel 5.
understood Tyler - thanks.
for the IQ5 specifically - since you say that with the IQ4 updates weren’t happening automatically, do you guys notify about IQ5 updates here like you did with the ADC update?
You will find FW update information in the under the Product Updates Tag. There will be a post once available.
