Thanks again. Here are some more questions, about monitoring and configuration.
On the first floor, I have 16 double hung windows, and 5 doors.
Panel:
Currently I have three keypads located at garage back door, one downstairs hall, and one in the Master bedroom. We won’t be doing keyfobs. Do folks just get a single panel and use their phones? Or are there keypads to extend the functionality of the controler in other rooms? Not even sure I said this right.
For the double hung windows, do I need 1 or 2 sensors? (I have 16 windows, I really hope I only need 1). Brand new windows, so I want the low profile RE11 mighty mouse sensors.
For the doors, all but one will be sensor’ed only, the main entry door will have remote control. So do I use the RE11’s for the doors too, or is there a more recommended sensor. For the main entry door, do I need remote control and sensor?
I want to automate both of my thermostats. SuretyDIY carries the 2GIG Z-Wave Remote Controllable Thermostat (CT100). There are many other models on the market although they are more expensive (http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=zwave%20thermostat&sprefix=zwave+%2Caps&rh=i%3Aaps%2Ck%3Azwave%20thermostat). I’m not itching to spend more than I need, but want to buy the right one to start with. Anything you can say to help me evaluate these is appreciated.
Smoke and Carbon Dioxide seem self explanatory. If there is something there not obvious to the Novice let me know.
Monitoring & Remote Control:
I know I need the Alarm.Com Gold interactive. What does adding the central station do. Can you help me understand what functions/features I gain with the central station and what I miss without?
Video Monitoring: Not sure I want to do that, but pricing makes sense. It is for the service, not per device correct?
Video Storage: I presume this is for when an event was triggered. How much functionality comes with base storage (minutes of recording per device…) and when do you need to upgrade?
Arming Schedules: So I currently have a programable thermostat, that is capable runing a couple day/time based routines? Is this what this is? Does it apply to “all” the sensors, such as HVAC, lighting, arming . . .
Extra Sensor Activity Monitoring: What is the difference between security monitoring and activity monitoring and how do I know when I need it?
Smart Energy Management: What is this?
Wellness Home Health Monitoring: What is this?
Extra Image Sensor Events: SO I read up on image sensor and think I understand this. Is this apart from “Extra Sensor Activity Monitoring”. Is this per event, meaning you are pre-paying .08-.20 cents per image delivery as a result of an event? How important is this, when should it be considered or avoided?
As I learn more I’ll probably have more questions. I’m technical, and this is still a lot to get my head around.
