Where is the GC2 panel tamper switch?
Can you tell me where the 2GIG GC2 tamper switch is on the panel? Last time I took the panel off the housing, I don’t recall it “beeping” like it used to
Check Q71 in programming. It sounds like it may be currently disabled. That would stop tamper alerts.
The tamper switch is at the top of the panel right next to where the set screw holds the panel to the back-plate. There is a small rubber cover to the switch
