What is my master code?
I am trying to set up my panel. I do not know the master code. Can you give that to me?
The master code should be 1111 unless it’s been changed. To see it, on your panel go to Security -> Menu -> Tool Box. At that point you will be prompted for your master code but you can enter your installer code there instead and it will work. Now choose User Management and you will see all your user codes, including your master code.
Best Regards,
Ryan
