I’m sure I will get blasted for asking this because it’s probably out here already. I have a vivint go control 2 panel, Zwave, and had it monitored with a camera. Can this system be unlocked to use as a DIY system? I currently cannot access the “Configuration Tab” in the panel. The installer must have used his own code. Any help is greatly appreciated.
If you have a 2gig Go! Control panel then this page will give you everything you need to get connected.
If you have the Sky panel instead you would need to replace the panel as there is no Alarm.com module for that unit.
Our initial command template, upon connecting service unlocks programming and defaults your installer code.
