Hello!
I’m setting up my Surety system for the first time, migrating from an existing 2GIG GC2 system. I purchased a Qolsys IQ Panel 4 with the 345 MHz card to reuse my existing Honeywell/2GIG wireless sensors, primarily door/window contacts.
I’ve successfully migrated all 30 sensors, and everything seems to be working great!
One thing I’d like to verify before wrapping up:
Our home has interconnected, hardwired Kidde smoke/CO detectors with battery backup. When one detector sounds, they all sound. We also have a wireless acoustic alarm listener mounted next to one of the detectors. It listens for the smoke alarm sound and reports an alarm to the security system.
This worked correctly on the old 2GIG system and appears to be working correctly on the new IQ Panel 4. I tested it using the smoke detector’s Test button, and the IQ Panel immediately registered a fire alarm.
I’ve configured the listener as follows:
Sensor Type: Smoke Detector
Sensor Group: 26 – Smoke-Heat
Loop: 2
Chime Type: Beep
Voice Prompts: On
Source: SecurityRF-345
Could you please confirm that this is the correct configuration for this type of sensor, particularly the sensor group? I want to ensure that whenever it triggers, the system generates the appropriate fire alarm and reports it correctly to the central monitoring station.
I’m also aware that the listener may not distinguish between smoke and CO alarm patterns, so I’d appreciate any guidance on whether that affects the recommended configuration.
Please let me know if you need any additional information or if there’s a better way to set this up.
Thanks!
Joe
