Can I use two IQ Panel2Plus (QK9202-AK2C-840) in the same system? One for the side door and one for the front door?
Thanks
Thanks
No. The IQ panel 2+ is the primary alarm panel and only one can be used per system/location.
A second IQ panel 2+ would be a separate Alarm.com account and location.
You would want the IQ Remote instead, which is a dedicated secondary touchscreen. The IQ panel 2+ supports partitions if you need to arm certain areas independent of others.
