can my 2GIG devices be excluded then paired with the IQ Panel 4?
Yes, but not to the panel you linked (the standard 319.5 version).
You would need the 345Mhz version of the IQ Panel 4 found here. Existing 2GIG 345 Mhz sensors can be reused with the new panel. The GC3 secondary keypads and any Image sensors would not work, and need to be replaced if applicable.
do these come with AT&T or Verizon Cellular capabilities?
By default we sell the Verizon model. The AT&T model is available on request, you can just add that in the order notes field when making the purchase.
can the IQ Panel 4 be used as a secondary controller with Hubitat?
This is not officially supported, but to clarify there would be no reason to or benefit if you are using the Surety Alarm plan. There would be no remote automation support, and adding as a secondary controller does not add any features to either controller or to Alarm.com, it just lets two controllers have control of a single list of Z-wave devices.
With Surety Alarm plan, there would be no Z-wave device control.
Lastly, does the Surety Alarm plan come with Central Station monitoring?
Professional monitoring can be enabled or disabled with the Alarm, Home, Protect, and Complete plans.
The goal would be to have motion, smoke, entry devices from the 2GIG hub report their status to Hubitat.
Looking at the Surety Alarm plan, it shows “5-diamond professional monitoring” … is this the same as central monitoring. The reason for asking is a discount on home insurance.
That would not work. The panel does not share sensor or alarm status via Z-wave.
Yes. You can download an insurance certificate on your subscription page in our website when you have active service.
