Unable to find installation button
I’m unable to locate the “installation” button in the panel in order to add sensors. I’ve tried rebooting the panel just in case but still have the same issue. Is there somewhere I’m not checking correctly?
You’ll need to use the Installer Code for that option to show up.
If you use your master user code to access Advanced Settings on the IQ Panel, Installation will not display as an option.
The default installer code is 1111. With a connected system you can reset your installer code remotely in the system manager here.
