For some reason, I keep getting an error when I try to download a clip on a selected timeline from the SVR (ADC-CSVR126, 16CH, 2TB)
There are options of downloading 1-minute and up to 5-minute clips. I am able to download 1 and 2-minute clips, but failed attempts on 3-5 minutes clips.
I have a feeling it’s not the internet connection but it’s rather the file size, but I’m not sure why. I on a gigabit speed which falls on ~600-800mpbs. If I can download 1 or 2 minute clips, I should be able to do download the other intervals. Plus a 2-minute clip is only ~100mb. I’m not trying to download a Spiderman movie. I was wondering if it’s a bug with the 3-5 minute intervals – like maybe the download request is timing out for some reason.
Its possible that it is a bug, but I am unable to confirm that. There is no information on ADCs end that suggests its a known issue. Ill follow up here if I am able to confirm that it is a bug.
I am also experiencing this issue. I can download clips from the SVR only if they are 2 minutes or shorter. Any of the longer options causes the same error message.
I’ve reached out to ADC to see if there have been other reports or if there are any specific suggestions other than an issue with file size and download. What browsers have you tried?
It looks like you have the CSVR126. Are you able to get longer clips via the CSVR126 interface?
For the record I am seeing this issue on 5 min clips from ADC-CSVR126-16CH via the ADC website. I need to try from the local device next but I need an HDMI monitor. I have to get video of a stranger on my porch.
Tested 30 seconds it worked but took about 5 mins to start downloading. I can test the other increments as well, but even 30 seconds was SLOWWWWW to process. Feels like an ADC side issue.
The SVR does have a valid Port forwarding rule, watching playback is fine just not downloading clips. Every time I need to get the clip locally from the unit but that’s not always great if I am not home. It’s a bummer the iOS app doesn’t allow download from the SVR as a test too.
