Tilt sensor programming
I’m having an issue with my tilt sensor setting off my alarm. I found a thread on here that shows installation programming instructions. So if i set it as a safety tilt and it trips, you wont call the police?
Correct. I recommend using this programming and then setting up rules for notification on when the garage doors are opened, rather than using the tilt sensor as a security sensor. Otherwise, often factors such as a heavy gust of wind, unloading groceries etc, leads to false alarms.
If you are like me, and want a functional garage door alarm with an intiating sensor, then go with something like a RE101? and a waterproof overhead garage door reed switch
