Can someone tell me if this company is reliable? I am trying to connect my three outdoor cameras, one doorbell, and a motion detector in my home so I can view the display on my phone and monitor my cameras.
It looks like your system is set up and ready to go but you still need to add the cameras, is that correct?
Are your cameras connected to wifi already?
Get started connecting cameras via the steps in the guide below:
Hello Jason, yes you are correct my camers are still hookup to Wifi, becuase a waeek ago is when my contract was over with ADT, but I had to wait additional week for them to release my code so I can go somewhere eles for less.
CONTROL. CONNECT. PROTECT. |
Someone replied to your post.
Jason jwcsurety Surety Team Member |
That makes sense, especially after switching over from ADT. I’d probably get the cameras connected to the new Wi-Fi first and then work through the Alarm.com enrollment process one at a time.
The fact that the cameras are already on Wi-Fi should make things a little easier. I’d also check that they’re compatible with the Alarm.com account before changing too many settings. Hopefully the transition goes smoothly once the old ADT setup is completely released.
I’d be interested to hear how the camera setup goes once you get everything enrolled.
Good morning, Jason:
OK, I have a question: when you say to connect my camera to the new source, what do you mean? It’s still connected to the internet. Should I remove it from the ADT setup and move it to your company’s setup? If so, how do I do that? Is it in my panel?
Eugene
You recently cancelled your ADT account correct? Those cameras would no longer be registered and should be ready to pair to your Surety account if your prior account was cancelled.
- Log into the Alarm.com Website.
- Click Video.
- Click Settings.
- Click Add Video Device.
Make sure the device you are using is on the same network as the cameras. Does Alarm.com prompt you to add any devices found onn your network at the top? If not, you may need to use the MAC address printed on the cameras.
GREETINGS, YES, YOU ARE CORRECT. Monday was a very busy day for me. I WILL WORK ON IT TUESDAY.
Thank you!
Eugene
- Click Video.
- Click Settings.
