My thermostat is not resetting to the schedule I have set up after the temperature is manually updated. How can I get it back on schedule?
Editing and saving the schedule again will resend the info to your panel. The next time the schedule should change, does the target temp get adjusted?
Also, if you have manually changed the target temp, did you do so at the thermostat or did you send an adjustment from the app? Can you verify the schedule has not been turned off?
