I,m only getting a tamper alert on a door contact when the alarm is disarmed. Is there any way to have tamper alerts enabled when the system is armed/away/stay?
I’m not seeing an associated suretyDIY subscription, so in order to best assist we would need to know more about your system.
What model of alarm panel are you using?
What model of door sensor is it?
In general, if a sensor is programmed as a monitored zone type, if it is tampered (cover removed) when the system is disarmed it will throw a tamper. If it is tampered when the system is armed that will result in an alarm signal.
If you are just opening/closing the door and getting a tamper that means something about the installation is incorrect. If a 2GIG Panel you likely have the wrong loop in programming.
