I went ahead and removed and readded it, that worked. Not sure the problem, I have had sync issues in the past and since it is the weekend I figured I would remove and add and see if it worked.
You can also visit the system manager here and there is a tool there to manually sync your Z-wave device list with Alarm.com.
Z-wave device additions do see delays in when the panel successfully syncs changes with Alarm.com at times, so you can use that tool to force the sync if necessary.
